Naujausias pranešimas: Samba kritinis pažeidžiamumas
frame
Sveiki apsilankę!
Prisijungti Registruotis
[MC] Too many open files klaida
GodPlayGodPlay Naujokas (-ė)
edited 2012 birželio 21 Į Pagalba
Sveiki mano serveryje stebuklingai atsirado štai tokie nežinomi errorai po kurių serveris lužta.
Dažniausias:
2012-06-15 11:29:47 [SEVERE] java.net.SocketException: Too many open files
2012-06-15 11:29:47 [SEVERE] 	at java.net.PlainSocketImpl.socketAccept(Native Method)
2012-06-15 11:29:47 [SEVERE] 	at java.net.PlainSocketImpl.accept(PlainSocketImpl.java:408)
2012-06-15 11:29:47 [SEVERE] 	at java.net.ServerSocket.implAccept(ServerSocket.java:462)
2012-06-15 11:29:47 [SEVERE] 	at java.net.ServerSocket.accept(ServerSocket.java:430)
2012-06-15 11:29:47 [SEVERE] 	at net.minecraft.server.NetworkAcceptThread.run(NetworkAcceptThread.java:24)
Tokių išmeta gal šimtas.
Dar vienas:
2012-06-15 15:26:28 [SEVERE] net.minecraft.server.WorldConlictException: Failed to check session lock, aborting
2012-06-15 15:26:28 [SEVERE] 	at net.minecraft.server.WorldNBTStorage.checkSession(WorldNBTStorage.java:74)
2012-06-15 15:26:28 [SEVERE] 	at net.minecraft.server.World.m(World.java:2718)
2012-06-15 15:26:28 [SEVERE] 	at net.minecraft.server.World.A(World.java:261)
2012-06-15 15:26:28 [SEVERE] 	at net.minecraft.server.World.save(World.java:251)
2012-06-15 15:26:28 [SEVERE] 	at net.minecraft.server.World.doTick(World.java:1750)
2012-06-15 15:26:28 [SEVERE] 	at net.minecraft.server.MinecraftServer.w(MinecraftServer.java:554)
2012-06-15 15:26:28 [SEVERE] 	at net.minecraft.server.MinecraftServer.run(MinecraftServer.java:459)
2012-06-15 15:26:28 [SEVERE] 	at net.minecraft.server.ThreadServerApplication.run(SourceFile:492)
2012-06-15 15:26:28 [SEVERE] Unexpected exception
Ir po visų errorų meta:
[INFO] Read timed out
[INFO] Connection reset
Serverio OS ir parametrai:
Linux Debian 6, 64bit.
10 GB of RAM
9 Ghz
20 HDD
30 Mbps
Naudoju java 6.
Labai prašau pagalbos ir būtų geriau kuo skubiau!
Iš anksto, ačiū.
Komentarai
  • IV_RomanLIV_RomanL Interneto vizija
    edited 2012 birželio 16
    Sveiki,
    klaida gali kilti dėl naudojamų minecraft plugin'ų. Įsitikinkite jog visi pluginai suderinami su naujausia minecraft versija. Taip pat, ši klaida pasireiškia kuomet centrinį minecraft serverį atakuoja DDoS ataka.
  • GodPlayGodPlay Naujokas (-ė)
    Tai galimi du variantai, DDoS ataka arba pluginų nesklandumai?
    Taip. Šiuo atveju problemos sprendimo ieškokite pašalinę visus plugin'us ir tuomet po vieną juos įjungdami. Taip rasite koks plugin'as stabdo serverio darbą.
    Bet man atrodo kad čia DDoS ataka nes anksčiau to nebuvo, ir serveris gerai veike su tais pačiais pluginais, jokių naujų neesu pridėjęs. Bet dabar ant antro VPS bandysiu paleisti tą patį serverį ir žiūrėsiu.
    edited 2012 birželio 17
    Na va, serveris jau veikia visą dieną ant kito hosto, ir jokių lužimų nebuvo, tai ką dabar belieka man daryti?
    edited 2012 birželio 18
    Patikslinkite probleminio serverio pirmus 6 IP adreso skaičius.
    edited 2012 birželio 19
    79.98.30.178 - prašau visas IP adresas.
    Sveiki,
    pateikite visų veikiančių serveryje plugin'ų sąrašą. Jei nepageidaujate viešinti, praneškite asmenine žinute.
    Gavome jūsų plugin'ų sąrašą. Pamėginkite pašalinti Spout bei SpoutEssentials plugin'us. Taip pat, įsitikinkite jog visi naudojami plugin'ai yra suderinami su MC 1.2.5 R4 ;)
    žinokite Spout pluginas man yra būtinas,o SpoutEssentials pabandysiu ištrinti. O jei nieko nepadės teks atsisveikinti ir su Spout arba ieškoti kokią įšeitį. O Jūs isitikinote jog tai ne DDoS ataka?
    Mazgas kuriame yra jūsų serveris nėra atakuojamas DDoS ataka tuo įsitikinome nuodugniai peržiūrėję ryšio įrangos duomenis. Jei rasite problemą Spout plugin'uose, informuokite apie tai šio plugin'o kūrėjus, galimai padės problemą pašalinti.
    Aišku, šendien ištryniau SpoutEssentials ir vakare pažiūrėsiu ar nenuluš. Ačiū už pagalbą.
    Serveris jau nebelūžta, problėma buvo SpoutEssentials plugin'e, radau kitą pluginą ir dar geresnį. Labai dėkoju už pagalbą.
Dedikuoti.lt
© 2007 - 2023 Dedikuoti.lt forumas, visos teisės saugumos.
