Naujausias pranešimas: Samba kritinis pažeidžiamumas
frame
Sveiki apsilankę!
Prisijungti Registruotis
Counter Strike Source serverio paleidimas
tomahauk666tomahauk666 Naujokas (-ė)
edited 2012 vasario 27 Į Pagalba
Sveiki. Turiu tokia beda,ngfaliu niekaip paleisti dedikuota Counter Strike Source serveri. Viska darau taip kaip parasyta SRCDS tinklapio forume. Visi zaidimo failai parsisiunte be problemu per hlds tools. Paleidziant serveri per PUTTY programa atsirtanda uzrasas kad nera tokios direktorijos ar kazkas panasus. Gal jus galetumet padeti man siuo klausimu.Jei kas yra kures ir siuo momentu turi veikianti css serveri,prasau jusu viska nuosekliai ir issamiai parasyti kaip tai yra daroma. Is anksto dekoju,Tomas.
Komentarai
  • MiXFiXMiXFiX Dalyvis (-ė)
    edited 2012 vasario 21
    Su kokia eilute paleidineji serveri?
  • tomahauk666tomahauk666 Naujokas (-ė)
    Bandziau taip: ./srcds_run -console -game cstrike +map de_dust
    -maxplayers 16 -autoupdate
    Po to kitaip: #!/bin/sh
    echo "Starting Cs:Source Server"
    sleep 1
    screen -A -m -d -S css-server ./
    de_dust +maxplayers 16 -autoupdate
    Vistiek taspats. Parasysiu po to koks tiksliai uzrsas pasirodo atlikus minetas komandas.
    O siaip viska dariau taip kap buvo parasyta:
    First of all download hldsupdatetool from the
    VALVe webserver. Make a dir called srcds_l, and
    save hldsupdatetool in that dir and run it. (Check
    this out when you have an uncompress error.)
    Command(s):
    mkdir srcds_l
    cd srcds_l
    wget http://www.steampowered.com/
    download/hldsupdatetool.bin
    chmod +x hldsupdatetool.bin
    ./hldsupdatetool.bin
    ./steam
    The new version of HLDSUpdateTool will be
    downloaded now. You will be returned to the
    console after its done.
    2) Downloading the files
    We can start downloading the files. This can take
    a few hours depending on the connection the
    server uses.
    Command(s):
    ./steam -command update -game
    "Counter-Strike Source" -dir .
    If you want to install a Half-Life 2 Deathmatch
    server, use "hl2mp" for the game switch.
    Go get yourself a cup of coffee.
    3) Starting srcds
    First edit (or create) srcds_l/cstrike/cfg/server.cfg
    like you want it to be. Now we are ready to run
    the srcds.
    and press enter. (-game hl2mp if it's a HL2DM
    server ofcourse)
    Your srcds is now up and running.
    Extra) Running srcds in background (re-
    attachable)
    We will make a script that will run the srcds in
    the background in a "screen"
    you will need to have screen installed for this.
    make a file called server.sh and put this in:
    Command(s):
    #!/bin/sh
    sleep 1
    Save the file, and chmod it to run
    Command(s):
    chmod +x server.sh
    If you want to start your server, simply run
    server.sh . It will start your srcd server in the
    background, to open it type:
    Command(s):
    screen -x css-server
    Bandyk: ./srcds_run -game cstrike +map de_dust2
    +maxplayers 16 -port 27015 &
    ir beto pakopijuok errora, jei nepasileis
    Dekui uz pagalba. Butunai parasysiu si vakar kaip ir kas ten.
    Na pabandziau paleist CSS:s serveri taip kaip parasei tu, erroas yra toks:
    -bash: ./srcds_run: No such file or directory
    [root@...... ~]# +maxplayers 16 -port 27015 &
    [1] 2362
    [root@...... ~]# -bash: +maxplayers: command not found
    [1}+ Exit 127 +maxplayers 16 -port 27015
    Hostname pakeiciau as pats.
    Gal yra kokiu minciu?
    Buciau labai dekingas uz pagalba.Is anksto dekoju,Tomas.
    vedi komanda:
    cd srcds_l
    cd orangebox
    tada vedi:
    Tiesiog iskart prisijunges prie serverio bandai leisti srcds, nors net neesi atsidares direktorijos, kur randasi srcds_run failas. :)
    Didelis aciu! Butinai pabandysim.Parasysiu ryt kas gavos:)...
    edited 2012 vasario 22
    Niekaip negaliu normaliai paleist dedikuoto counter strike source serverio. Reikia zmoniu patarimu kurie tiksliai zinotu problemos priezasti:
    cd srcds_l
    cd css
    ./srcds_run -console -game cstrike -port 27015
    +ip 79.98.30.172 +map de_dust +maxplayers 16
    Serveris lyg ir pasileido bet steam programos
    serveriu sarase mano dedikuoto css:s serverio
    nesimato.Matos tik dedikuoto serverio ip adresas
    ir mano interneto.Uzrasas salia: not responding.
    Kas galetu buti? Gal is foto eis ka nors suprast:
    http://imageshack.us/photo/my-images/210/snap5dx.jpg/
    http://imageshack.us/photo/my-images/641/snap6y.jpg/ :(
  • IV_LinasJIV_LinasJ Interneto vizija
    edited 2012 vasario 26
    Serverių sąraše nematau, kad būtų ivestas serverio ip adresas.
    Reikia pridėti serverį 79.98.30.172:27015 į faworites, norint jį matyti šiame sąraše.
    Aciu uz pagalba.Problema isspresta.Priezastis kitame buvo.
  • IV_RomanLIV_RomanL Interneto vizija
    Ateičiai tikrai būtų naudinga jei pasidalintumėte su kitais forumo lankytojais, kokiu būdu išsprendėte problemą? :)
    Problema issprendziau sekanciu budu: 1.Steam programos serveriu favorite skilyje istryniau 2 serverius su uzrasais- not responding. 2 Pabandziau is naujo surasti steam serveriu paieskos lauke savo dedikuota serveri.Radau!
    3. Irasiau ji i favoritus.
    4. Prisijungiau prie savo serverio.
Dedikuoti.lt
© 2007 - 2023 Dedikuoti.lt forumas, visos teisės saugumos.
